-   -   Right size supply lines to bathrooms (http://www.diychatroom.com/f7/right-size-supply-lines-bathrooms-60435/)
Mudball 12-28-2009 06:23 AM
Looking for opinions on running supply lines to bathrooms and kitchen or some kind of calculator. We dont have anything extra out of the ordinary. Bathrooms are a shower, toilet, and sink. The kitchen will have sink and possible future dishwasher. So then would the 1/2" pex supply lines be alright or would we need to consider larger ?
JGibbsRemodel 12-28-2009 06:52 AM
1/2" is fine. this is typical in all houses
Just Bill 12-28-2009 07:18 AM
Typically, water enters the house in 1 or 3/4" pipe. It should stay at 3/4 as close as possible to its' final fixture, then go to 1/2". If it is 1/2" from the house entry, you can have low pressure problems when someone else opens a faucet or flushes a toilet.
tpolk 12-28-2009 08:28 AM
I always run 3/4 then drop to 1/2 at fixture not that much more cost wise and keeps volume up. I think here you are allowed to drop to 1/2 when down to two fixtures on run
paul100 12-28-2009 08:36 PM
Are you doing all homeruns with the pex? If so then you will be making all the connections in the basement using a manifold. If that is the case then 1\2" is fine. If no manifold then follow what the other posters are saying and run a larger line close to the fixture before you switch to 1/2".
Mudball 12-28-2009 10:45 PM
Thank you all very much. I believe its 1" coming into the house. We are building what you might call a basement house. Concrete block walls and slab floor. We live out in the sticks and are not subject to code inspections or permits so I have to make sure they do it right. One plumber I was talking to said that if he gets the job he was going to run 1/2" from the utility room to supply the bathrooms which each bathroom has a shower, toilet and sink. Anyway I think I understand that from the 1" supply line in the utility room that the plumber will need to run 3/4" to each bathroom wall and run separate individual 1/2" off that 3/4" for each fixture. Did I say that right ?
AndrewF 12-28-2009 11:12 PM
More or less, you did.
I tend to run 3/4" as close to the room/fixtures and split from there.
Mudball 12-29-2009 09:26 PM
Thanks AndrewF that sounds great. I will make sure that 3/4" is the minimum run to each bathroom and then go from there.
