Riannai Tankless Water Heater Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2011, 09:24 PM   #1
Question
Riannai tankless water heater venting
Our old water heater rusted out and sprung a leak, so no hot water until it gets replaced. My brother/landlord decided he wanted to try tankless. The gas and water seem basic enought just have to go and get an external pressure relief valve. My question is on the venting, my understanding is that the concentric pipes are used because todays homes are so airtight. I don't have that problem/benifit. Lots of air leaks. So would it be possible to vent just the exhaust up the chimney like the old one or do I need to use both pipes and vent through the wall? The pipes suggested are steel inner and stell or plastic outer, not stainless
Thanks for any help
Keith425 is offline   Reply With Quote
Old 04-23-2011, 08:24 PM   #2
Plumb or Die!
Your combustion air needs to draw from outside.
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
breid1903 (04-23-2011)
Old 05-16-2011, 08:04 PM   #3
Bought the right venting for 2 reasons, 1 just safer that way, and 2 my chimney flue isn't stainless so it won't take the heat. Pricing is ridiculess though. over $200 for 18 inches of venting
Tankless water heater to pre-heat incoming water matthet Plumbing 35 01-06-2017 01:39 AM
Adding a tankless water heater schultz56 Plumbing 26 01-22-2011 11:46 AM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Tankless water heater vs. electrical water heater? imola ghost Electrical 19 09-08-2008 03:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
