| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How a Sprinkler Head Works
by Expert Village
Hi I'm Fernando with Expert Village going over how a sprinkler head actually works and as you can see this sprinkler is connected to the pvc piping. When the pressure comes from the valve which is the water rushes in and fills up the piping it then goes... Read More »
How to Check Exterior Faucets for Cracks or Damage
by Expert Village
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking all of our exterior faucets. First off you want to make sure that you disconnect all hoses so that they don't freeze and cause a pipe to break. The next thing I'll do is I... Read More »
Re-Attaching Water Line to Toilet
by Expert Village
Last but not least to set the toilet is the supply line. The braided supply lines come in different lengths, and when we're too close to the valve, and I 'm afraid of kinking it, I go with the longer supply line and loop it. Now we just need a pair of... Read More »
Using a Slow Drip with a Drip Tape to Water Garden Plants
by Expert Village
So again we are going to flush this out while it is open on the end, wiggle it, anything comes out and we turn that off. Our drip tape, there are products you could buy to close it, but you can also just tie a knot in it and pull it tight. If it leaks a... Read More »
How to Prevent House Mold
by eHow.com
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
