Rheem Powervent Water Heater Gas Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2012, 04:59 PM   #1
Rheem powervent water heater gas leak
Just installed a new Rheem powervent water heater (40 gallon) and my wife smelled gas in the basement a week later. I checked the gas lines with soap and water and didn't find any leaks, but I put my nose by the gas valve on the water heater itself and I can smell gas. The gas company verified that there's a ".03" leak there. They didn't red flag it.
I then called Rheem and the technical support person said that a gas "leak" there is normal. Is that correct? He said that without a small vent (which is where the leak comes from) there would be vaporlock. I'd like to get your advice. Thanks!
DIY1 is offline   Reply With Quote
Tags
natural gas , water heater
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Rheem Water Heater Questions 1972gs455 HVAC 0 01-15-2010 10:44 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 06:00 AM
