Rheem Gas Water Heater Make High Freq. Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2012, 01:25 AM   #1
Rewards Points: 33
Rheem Gas Water Heater make high freq. noise
Hello,
My Rheem gas water heater (fairly new) make high freq. noise when use hot water. This doesn't sound like water hammer. I am not sure how to start troubleshoot this. I can hear the noise close to the burner.
Thank in advance.
cfreak is offline   Reply With Quote
Old 09-19-2012, 08:13 AM   #2
Rewards Points: 1,452
Drain about a gallon (more if there is visible sediment or discoloration) from the bottom of the water heater.
A squeal usually means a constriction in the water line for example a valve with a loose washer or only partially open.
Was this squeal alwasy there or just appeared suddenly?
Old 09-19-2012, 08:27 AM   #3
Rewards Points: 582
Originally Posted by cfreak View Post
Hello,
Thank in advance.
may need to have gas pressure checked if it only makes noise when burnners start up......
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Eternal Hybrid Water Heater Noise jacquesstrap Plumbing 7 02-03-2012 03:31 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
