Reworking Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2012, 02:48 PM   #1
Rewards Points: 87
reworking drain pipe
Is the below mockup of how I would like to rework my shower drain acceptable?
I know the drain needs to be 2" pipe, was just using what I had around to mock it up.
hellonoko is offline   Reply With Quote
Old 09-15-2012, 10:57 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 984
were are you located?
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 09-16-2012, 12:15 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
Not ideal, but it will work.
I'd replace the san tee with a combo.
And the vent should not go horizontal until 42" above the floor, but that is not critical in my opinion. Your original installer seemed to think that too
Old 09-16-2012, 01:48 AM   #4
Rewards Points: 87
@Javiles - I am in Oregon.
@TheEplumber - What is a combo? The original setup passed inspection so I guess its OK here?
What I am trying to do is move the vent stack back so it can go inside a bench for the shower that runs along that wall.
Is there another way I should do this?
Old 09-16-2012, 02:21 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm assuming that a wall is going there where the vent is currently?
The vent only has to rise a minimum of 6" above the flood rim of the fixture being served in oregon, so you are fine. The drain must be 2" and the distance from vent to trap maxes out at 5 feet. Only problem I see is that if you were to have outlets in that wall on the back side, the pipe may be in the way. We normally run them at 52" to stay above light switches or countertop plugs. It wouldn't hurt anything to raise them up.
Don't need a combo either, a santee is fine in that application.
Where are you at in Oregon?
Journeyman Plumber
Old 09-16-2012, 06:19 AM   #6
Since I am not a plumber, I apologize if asking a dumb question but can OP do this?
allthumbsdiy is offline   Reply With Quote
Old 09-16-2012, 10:51 AM   #7
Doing it myself
Alan's Avatar
No. The vent has to come off the top of the pipe, not the side.
Journeyman Plumber
Old 09-16-2012, 12:10 PM   #8
Rewards Points: 87
@Alan - I am putting a shower bench along that wall thus the need to make the vent stack closer to the wall and short. Originally it was going inside a wall but I decided to make the shower a bit bigger / nicer.
There are outlet plugs on the other side of that plumbing wall but ive set it up to not interfere with the plumbing.
I am in the Southern Oregon area.
Old 09-16-2012, 01:10 PM   #9
Doing it myself
Alan's Avatar
45 * is considered vertical.... if you put a 45* fitting directly on top of the existing fitting, will that give you enough room for the bench? It would be a lot less work.
Journeyman Plumber
Old 09-16-2012, 01:21 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 984
i don't understand that Code, much easier under the IPC you could get rid of second vent for the shower and just use one.
Old 09-16-2012, 01:30 PM   #11
Rewards Points: 87
@Alan - The position of the new pipe in the picture is about 1 foot from the wall. I think if I did it with a 45* it would come out of the floor too soon / cause me to make my bench very wide. Maybe what you mean is in your drawing going.... slightly up over with a 45* then horizontal to meet the existing vent? The depth of the concrete there is only about 4 inches so I dont think I would have room.
@ Javiles - Not sure what you mean? I am not adding a 2nd vent I am moving the existing vent. I think if I didn't have a vent there the next vent would be upstairs with the showers there and that would not really work as venting for the lower shower.
Old 09-16-2012, 03:01 PM   #12
Doing it myself
Alan's Avatar
Your original idea will work just fine then. Good luck!
Journeyman Plumber
Old 09-16-2012, 10:08 PM   #13
Bombastic Idiot
notmrjohn's Avatar
I'm not sure i understand what you're describing, noko, could you post a picture?
I want to salute you all, this is one of the finest examples of " eight-by-ten colour glossy photographs with circles and arrows and a paragraph on the back of each one explaining what each one was" that I have seen since I dodged the draft
Speakin of draft, if a beer makin journeyman plumber says go for it, go for it.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
PVC sink drain pipe... Ed911 Plumbing 4 12-01-2011 11:09 AM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 02:48 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
