Reverse Osmosis Recommendation? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2011, 10:17 PM   #1
Reverse osmosis recommendation?
Can anyone recommend a good under the sink reverse osmosis filter? I have no idea where to start, or what price range I should be in to get a good one. Also, do the under the sink models have the ability to tie into the refrigerator to filter the ice and water from there? Or would that be a separate unit? Thanks in advance for your help!
Leanne1 is offline   Reply With Quote
Old 10-13-2011, 10:22 AM   #2
bradnailer's Avatar
We use RO units where we live as the water has a bad taste. You can get a unit at the the two big home improvement warehouses for under $200. Installation is easy. You will need to tee in to the outlet line and run a plastic line over to your fridge to have RO ice and cold water. Generally that isn't a big chore either. Depending on your water and how much you use, you will need to plan on replacing the filters every few years.
bradnailer is offline   Reply With Quote
Old 10-15-2011, 08:30 PM   #3
Thanks, brad! Bought one at home depot and hubby thinks he can handle the install. We appreciate the help and are looking forward to some tasteless water!
Aquatec Permeate Pump Noise, Reverse Osmosis nissmo66 General DIY Discussions 2 01-16-2012 01:20 PM
Reverse osmosis hookup trouble bweaver15 Plumbing 0 01-03-2011 09:43 PM
Reverse Osmosis Options wiz561 Plumbing 0 11-25-2010 10:13 AM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 12:14 AM
Changing reverse osmosis water filters awayeli General DIY Discussions 2 07-05-2008 02:20 PM
