Reusing Fernco - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2013, 10:53 PM   #1
Rewards Points: 225
reusing fernco
Replaced cast iron drain from toilet to stack. Used pvc for drain and a fernco type fitting to connect to the cast iron stack. Not sure of the brand of fitting. Need to remove the drain pipe. Can the fernco type of fitting be reused? Assembly is about a year old. Do not plan on removing fitting from cast iron but pulling out the pvc drain. If the fernco type had to be removed from the cast iron can it be reused? Thank you.
gt1935 is offline   Reply With Quote
Old 11-14-2013, 11:43 PM   #2
MarginallyQualified
Rewards Points: 2,464
Somewhere in the probably to maybe range.
But for the savings of $5 or $10 to buy a new one...
I can't see the point of bothering.
The Following User Says Thank You to TarheelTerp For This Useful Post:
gt1935 (11-22-2013)
Old 11-15-2013, 05:11 AM   #3
DIY staff
Rewards Points: 7,174
At a year old? You will be fine----However--if in doubt--replace it
gt1935 (11-22-2013)
Old 11-20-2013, 10:50 PM   #4
Rewards Points: 225
Is that a yes? It is a year old and plan on leaving the fitting on the cast iron and replacing the pvc drainpipe that goes into the fitting on the cast iron. Thanks.
Old 11-21-2013, 06:43 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
is that a yes? it is a year old and plan on leaving the fitting on the cast iron and replacing the pvc drainpipe that goes into the fitting on the cast iron. Thanks.
Y e s,....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
gt1935 (11-22-2013)
Curious Question - Fernco Couplings Chris Sweeney Plumbing 15 10-18-2013 08:31 PM
Fernco stack support rtoni Plumbing 3 05-27-2011 10:13 AM
Recycling and reusing paper MagicalHome Green Home Improvement 2 11-08-2010 10:02 AM
Fernco waxless toilet seals Duane 70 Plumbing 8 01-02-2009 01:35 PM
fernco coupling farrington135 Plumbing 2 03-09-2007 09:12 AM
