Reuse Rubber PVC Coupling? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2012, 08:35 PM   #16
Master Plumber
Javiles's Avatar
Rewards Points: 994
Originally Posted by csab_ View Post
Both the tub and the sink are slow. Neither is completely stopped. The toilet is fine. So it's pretty clear where clog must be.
ok where’s the partial obstruction ?
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-16-2012, 10:04 PM   #17
Rewards Points: 485
Well... I thought it must be right after the sanitary tee, but before the stack... Well, not. I took apart the rubber coupling and tried to snake out the 2 inch pipe and the snake went down easily several feet. So I realized that the tub was slow independently from the sink. I cleaned the drain of the tub, and voila, tub is fine. Then I tried to snake out the sink drain after removing the trap. I hit the obstruction about 2 ft into the pipe. I tried everything: slow, fast, back, forth, but unable to break up or pull out the clog. I put it together and now the sink is completely stopped.
I guess my only choice now (short of calling a real plumber) is to cut the old sanitary tee out of the pipe, and snake it from down up. Then replace the tee with PVC (I think the sanitary tee can stay, after all that was not what was clogged), and put in a cleanout, just in case.
csab_ is online now   Reply With Quote
Old 01-16-2012, 10:28 PM   #18
Master Plumber
Javiles's Avatar
Rewards Points: 994
The machine and cable you use is very important what exactly are you using post pic’s if you can. Especially the cable head.
Old 01-16-2012, 11:36 PM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 562
if your going to replace the tee(and you should), use a combination wye- 1/8 bend. Join it to the existing line with a no-hub coupling like your current coupling. Use a pvc coupling on the tub side. This is the proper fitting when going from vertical to horizontal.
Old 01-17-2012, 11:56 PM   #20
Rewards Points: 485
I bought the material today, the combination tee-wye, a cleanout, etc. I'll do the job tomorrow or as soon as I can find time. I'll post some pictures when I'm done. I hope I won't do anything ridiculous...
Old 01-21-2012, 10:18 PM   #21
Rewards Points: 485
Here is the promised photo:
It works, but I'm not all that satisfied. For two reasons.
1) First I cut the vertical sink pipe too long, and since I glued on a minimal length vertical PVC to the tee-wye, I had to cut more of the galvanized steel pipe. After that it became too short, so the rubber coupling is barely hanging on both the PVC and the steel. Of course I could make the PVC going up a little longer, but then I would have to buy a new tee-wye, wye, threaded whatever-it's-called, and redo the cementing. I'll just watch carefully, and if it starts to leak I will have to do it.
2) This problem existed before I even started this work, but I only discovered it after putting things together: the tub pipe doesn't have a drop. I'm sure water is pooling inside the pipe, so it's only a question of time until I develop a leak or blockage. We will remodel the whole bathroom eventually anyway, so I just hope it will work until then.
BTW the clog was in the vertical sink pipe. Once the sanitary tee was cut off, I went up vertically with the snake and within one minute, the clog was gone and I took a shower of dirty water.
The Following User Says Thank You to csab_ For This Useful Post:
TheEplumber (01-21-2012)
Old 01-21-2012, 10:23 PM   #22
Plumber
Rewards Points: 562
You can replace the vertical no-hub coupling with a rubber fernco. They are slightly longer (maybe 4"?) and would work just fine.
The Following User Says Thank You to TheEplumber For This Useful Post:
Alan (01-21-2012)
Using a rubber coupling instead of PVC coupling sukhenkoi Plumbing 2 04-05-2011 06:53 AM
Leak at rubber coupling in stack WillK Plumbing 7 03-14-2011 01:37 PM
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 08:15 AM
Rubber Roof Sealant ninghai Roofing/Siding 17 03-08-2010 08:58 PM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
