Reuse Rubber PVC Coupling? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2012, 05:48 PM   #1
Rewards Points: 239
reuse rubber PVC coupling?
Just a simple question. Can you reuse a PVC rubber coupling if you open it up? The convenient place for me to snake out a drain would be at a rubber coupling, but before I open it up, I want to know if I need to buy a new one first.
csab_ is offline   Reply With Quote
Old 01-15-2012, 05:51 PM   #2
Rewards Points: 12,860
Talking about the ones with hose clamps on each end? If so there sold at Lowes, HD, any hardware store, plumbing supply.
Show us a picture of what your trying to do and I'd bet we can tell you a better way to do this next time.
plummen (01-15-2012)
Old 01-15-2012, 05:52 PM   #3
MarginallyQualified
Rewards Points: 2,464
worse things have been done
The convenient place for me to snake out a drain would be at a rubber coupling...
how about setting a proper clean out there instead?
Old 01-15-2012, 09:00 PM   #4
Rewards Points: 239
Here is the image.
A proper cleanout sounds quite a bit more work than just disconnect this quickly. How many times will I need that in my life?
Old 01-15-2012, 09:07 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Here is the image.
Actually not too many more before the threads rot out on the galvanized and you have a leaker.
Change that baby out.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
csab_ (01-15-2012), TarheelTerp (01-15-2012)
Old 01-15-2012, 09:10 PM   #6
Well #1 one all that old steel plumbing needs to go. If it's not leaking now it will. It rust up from the inside and will get smaller and rougher as it gets older.
#2 that's the wrong type of tee in that line and cause the line to plug up.
a clean out could be added by simply cutting that PVC and adding a clean out Tee.
As far as how often your going to have to clean it out, you tell us. Your having to do it now, right.
csab_ (01-15-2012)
Old 01-15-2012, 09:51 PM   #7
Rewards Points: 239
Guys, I appreciate all the advice. Tell me more. We recently bought this 55 year old house and there is a lot to do.
Here is my pipe setup coming from the bathroom:
(Don't tell me about the amateur wiring - I know - it will be fixed.)
The PVC pipe is the bathtub drain. The vertical one is (probably) the sink. And the big one is (I think) the toilet. It's hard to see, but there is a vertical pipe in the far corner, and if I'm not mistaken, that's the vent.
The steel pipes eventually go into clay pipes in the ground. I know this because we recently dug up the sewer in the backyard to install a backflow preventer valve. But where the steel pipe exits the basement, it's under a porch outside, so I can't really dig it up to replace that steel pipe. OK, I understand that the T is the wrong type. What type should I change it to? All in all, what do you recommend?
All the help is very much appreciated.
Old 01-15-2012, 11:05 PM   #8
MarginallyQualified
The tee in front of the rubber coupler needs to go...
replace it with a sanitary tee. <--Need to do
immediately behind it put in a 45 tee with the clean-out cap. <-- Need to do
then the rest of that section down to the stack <-- May as well do
and the vertical riser section up to wherever it goes. <--Won't hurt to do
Old 01-15-2012, 11:19 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 984
Letís take this one step at a time, what is clogged? If itís a tub or shower you can just usually on a tub go through the over flow and in a shower remove the grid and snake through that, providing that you have enough cable to get to your clog. Best to cable with water in the line so when you break the clog the standing water will help flush it way, run plenty of water after clog breaks and while you finish Roding the line. By the way the suggestions made by some of these guys are something to keep in mind that plumbing needs to be taken care of.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-16-2012, 09:02 AM   #10
Rewards Points: 239
Originally Posted by Javiles
Let’s take this one step at a time, what is clogged? If it’s a tub or shower you can just usually on a tub go through the over flow and in a shower remove the grid and snake through that, providing that you have enough cable to get to your clog. Best to cable with water in the line so when you break the clog the standing water will help flush it way, run plenty of water after clog breaks and while you finish Roding the line. By the way the suggestions made by some of these guys are something to keep in mind that plumbing needs to be taken care of.
Both the tub and the sink are slow. Neither is completely stopped. The toilet is fine. So it's pretty clear where clog must be.
Old 01-16-2012, 11:15 AM   #11
Rewards Points: 3,130
Look at the OP's earlier post with photo - that tee looks like it's already a sanitary tee. That's wrong; needs to be a wye.
The Following User Says Thank You to md2lgyk For This Useful Post:
TarheelTerp (01-16-2012)
Old 01-16-2012, 11:53 AM   #12
Those lines need to be 2" and vented if there not.
Old 01-16-2012, 01:47 PM   #13
Rewards Points: 239
Indeed, it's sanitary. So do I really need to replace it with a wye?
Old 01-16-2012, 01:59 PM   #14
Rewards Points: 239
The vertical from the sink is 1 1/2 inch, same is the PVC from the bathtub, but after the tee, it's a 2 inch pipe. As for the vents: I can see that the tub is vented, and there seems to be a vertical vent on the main stack. That's what I see, but I assume they all vented correctly.
Old 01-16-2012, 04:51 PM   #15
MarginallyQualified
In the pic I first thought you had nothing there at all...
that the drain was t-boning the lateral.
The prescription is that you need more oomph! when that stuff comes down the pipe
see what will fit (a wye on the line and a 45?)
Using a rubber coupling instead of PVC coupling sukhenkoi Plumbing 2 04-05-2011 07:53 AM
Leak at rubber coupling in stack WillK Plumbing 7 03-14-2011 02:37 PM
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 09:15 AM
Rubber Roof Sealant ninghai Roofing/Siding 17 03-08-2010 09:58 PM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 02:02 PM
