Retrofitting An Ejector Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2012, 12:32 PM   #1
Retrofitting an ejector pump
I'm putting a bathroom in the basement, everythings already rough plumbed, problem is that the orginal owners had a Zoeller M137-C pump in the ejector pit with a 1.5" discharge to the main sewer line (serves laundry and 1 sink). As I understand it this won't work for toilet. Is there a way to get around completely replacing the 1.5" pipe with 2" pipe? I'd like to avoid cutting into the sewer line. Thanks!
Joski is offline   Reply With Quote
Old 04-05-2012, 01:53 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
The UPC code requires 2" ejection line with a full port ball or gate valve and a check valve.
Old 04-05-2012, 10:00 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Yes, BUT, if the system is engineered, they can put in whatever they want.
We have this situation in our town in quite a few places actually.
Pumps are pumping up 1.5" discharge line approximately 200 ft where they dump into a shared 3" discharge pipe which travels approximately 100 more feet before it goes to gravity.
I personally think that engineer should be shot. <_<
Journeyman Plumber
Old 04-05-2012, 10:03 PM   #4
Doing it myself
Alan's Avatar
And so : In response to the original post (sorry I got lost there)
I'm a little confused. 1.5" discharge aside (it does work, i've seen it work, it's just not the best idea and doesn't meet code for that matter)
You're saying the basement bathroom is already plumbed into the ejector?
Journeyman Plumber
Old 04-05-2012, 10:18 PM   #5
Plumber
Rewards Points: 682
I just did one in 1 1/4" for 80ft to the city's pressure system. I asked the city engineer to verify the size cuz I didn't believe him. Sure enough, 1 1/4" was stubbed to the property.
But I think the OP's situation will require a 2" line for a grinder
Tags
basement , bathroom , ejector pump
Retrofitting Ground Wires - To Code!? Thadius856 Electrical 21 07-11-2011 04:25 AM
Retrofitting heat flue in comp shingle roof Steve Burke Roofing/Siding 0 04-14-2011 09:48 AM
Retrofitting and icemaker box bubbler Plumbing 1 03-20-2011 04:05 PM
Retrofitting wall vent on an OTR microwave/hood comb chrissi Appliances 3 11-13-2010 09:03 AM
Retrofitting Vintage doorknobs on bathroom/bedroom doors biggabush Remodeling 1 01-27-2010 09:36 PM
