Restarting An Old Well - Options? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2010, 02:29 PM   #1
Rewards Points: 153
Restarting an old well - options?
My home was built in the 1940's
The original well next to the house in a pit.
This has the pipes still showing where the above ground well pump used to sit.
In 2000 a new well was dug on the other side of the house. I am assuming this was done due to the size of the house was doubled.
I do not know why the old well was abandoned.
I was going to re-use the old well for outside watering. - Possibly with a smaller more efficient pump.
Any thoughts on this?
theedudenator is online now   Reply With Quote
Old 07-06-2010, 03:24 PM   #2
I would not plan on this working.
Wells do not last forever and not using them is hard on them.
But, if you still want to try, get a pump and hook it up.
BTW, if the well was really abandon, it has been pumped full of cement or bentonite. It can not be of service.
Mr. Green is offline   Reply With Quote
Old 07-06-2010, 03:43 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Old wells rarely if ever work. You would be better off putting a new one down with a new pump, pressure tank, etc.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-06-2010, 04:27 PM   #4
Licensed Master Plumber
Step 1, pull the cap and see if theres any water down there.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-07-2010, 09:50 AM   #5
Rewards Points: 1,448
Most likely the old well was abandoned because it did not delver enough gallons per minute (or maybe went completely dry).
This is significant if you want to use it for a sprinkler system.
Need HELP swapping a Vision pro 8320u1008 to an IAQ one N01B4ME HVAC 161 01-10-2011 03:30 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Waterproof Deck Options sendres Building & Construction 7 05-15-2009 12:18 PM
Garage/shop floor options philS Flooring 5 05-06-2009 07:10 AM
