Resilient Tile - Under Toilet Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 06:50 AM   #1
Rewards Points: 27
Resilient tile - under toilet flange?
I'm installing a toilet over a floor that will have resilient self-stick tiles. Should I run the tiles under the lip of the toilet flange? Or should the flange rest only on the plywood floor?
Eric
mn1247 is offline   Reply With Quote
Old 06-23-2011, 07:11 AM   #2
DIY staff
Rewards Points: 7,174
Either way is acceptable----do what is easiest.
Old 06-23-2011, 09:13 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Our local code technically requires that the flange be set on top of the finished floor.
What I find odd these days is that a lot of the lower end toilets do not have the space below them to leave enough wax between the base of the bowl and the flange if the flange was on top of the finished floor. So what happens when you set the toilet is that you squish all of the wax out from underneath, and the toilet is only sitting on the flange. The base is 1/4" off the floor. Then you end up having to pull it back up and re wax it, and use wedges. . . i hate it.
In your case, being that you're using linoleum tiles, it won't make a difference. Keep in mind you might need some wedges.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
tpolk (06-23-2011)
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 08:34 AM
New toilet doesn't sit flush on new tile toycosm Kitchen & Bath Remodeling 6 05-12-2011 07:25 AM
toilet flange installation rcassidy Plumbing 1 11-17-2010 02:12 PM
someone installed tile over my toilet flange! Emergesunscathe Flooring 3 10-13-2010 01:44 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
