Residential Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2010, 01:50 PM   #1
Just call me Andrew
Rewards Points: 1,020
Residential water pressure
My parents have 180 PSI coming into their house and use a Watts regulator to lower it to 50 PSI. One shower by itself is...acceptable (to me) but barely. If two people shower at once or one person + a toilet flushing, it's really low.
It is safe to raise the house pressure to..say...80 PSI? If so, how is this done? Tightening the screw on the regulator?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 03-02-2010, 01:57 PM   #2
usually 60 is good if constant which should be without press tank. 80 might damage fixtures. yes should be locking nut and screw not sure of rotation
The older I get the better I was
Old 03-02-2010, 09:25 PM   #3
Rewards Points: 152
You're right, you turn up the pressure by tightening the screw.
I agree with the previous poster, be safest to keep it at around 60psi.
burnt03 is offline   Reply With Quote
Old 03-02-2010, 09:29 PM   #4
Just call me Andrew
I have a psi meter that hooks up to a hose spigot. This a good way to test the pressure? Any idea how much I'd need to turn the screw to go from 50 to 60 psi?
Andrew
Old 03-02-2010, 09:36 PM   #5
I have almost 80 here & at the last house
Last house I had a garden house burst
I haven't tried adjusting the pressure down
I think it would depend upon the valve...try it little by little maybe ?
Old 03-02-2010, 09:39 PM   #6
Just call me Andrew
Yeah, I'll just have my dad stand out by the spigot watching the gauge while I slowly turn. My house is about running at about 80 here in my house, but I think my parents will be nervous going that high. 60 or so would be good I think.
Andrew
Old 03-02-2010, 09:50 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
the pressure on the gauge probably wont change untill some pressure is relieved by opening a valve/faucet somewhere in the system
plummen is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
