Residential Water Meter Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2010, 07:28 PM   #1
nix
residential water meter connection
I have a 3/4 in. steel pipe water supply line to my house that needs replacing. The connection on the water meter is a threaded female connector with a tail piece that looks to be welded to a coupling which is welded to my supply line. Where can I get a fitting to connect to the water meter that will also connect to my new water line without welding? I plan to come out of the meter with steel or galvanized pipe for about a foot or 15 inches and convert to PVC.
Thanks, Nick
nix is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
Water Meter connection Ultrarunner2017 Plumbing 4 03-17-2009 10:11 PM
