Resetting Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2010, 09:45 AM   #1
resetting toilet
I just noticed that the toilet rocks and that the bolt that holds toilet to the flange has come loose.
When I go to remove toilet and reset, do I need to replace the wax ring?
jepark is offline   Reply With Quote
Old 02-20-2010, 10:06 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Yes.
Are you by chance a manager at mcdonalds?
Journeyman Plumber
Alan is online now   Reply With Quote
Old 02-20-2010, 10:59 AM   #3
Solutions (handyman)
Rewards Points: 364
Tiolet repair
I'd say yes to the wax ring. Whenever you disturb something around the tiolet, the seal isn't true any more. It may be fine, but for the coct of the wax ring, it is better to be safe than sorry. Also, when you have the tiolet off, check the wood and the bolts that hold the tiolet in place. Replace them if needed.
Regards.
Mark Harvey is offline   Reply With Quote
Old 02-20-2010, 10:06 PM   #4
Rewards Points: 1,512
Do a test fit of the toilet without the wax ring to be sure the rocking problem is fully corrected.
Otherwise the new wax ring could become deformed and no longer work.
Old 02-21-2010, 08:24 AM   #5
When ever I remove and replace a toilet I always replace the nuts, bolts, washers, wax ring. The cost is so minimal and the result is well worth it. Believe me.
SULTINI is offline   Reply With Quote
Old 02-21-2010, 08:43 AM   #6
Man of many hats
wrangler's Avatar
Rewards Points: 354
Though usually, it might make sense to purchase the wax ring and flange bolts before you remove the commode, it might be better to remove the toilet first and inspect the flange. It is quite possible that you have a broken pvc flange, hence the loose flange bolt. I'd take a look first to save yourself another trip to the hardware store to buy a new flange or flange repair kit.
Man of many hats
wrangler is offline   Reply With Quote
Old 02-21-2010, 01:04 PM   #7
Good point, however in my answer I didn't say when before or after I just said I always buy new for re installation. I' ve even had a spare set on the shelf at times they are so cheap and worth it. Keep it simple.
Old 02-21-2010, 01:21 PM   #8
Man of many hats
wrangler's Avatar
Rewards Points: 354
I wasn't trying to correct your post, but to point out that he may well have a damaged flange. I agree it is good to keep spares of many parts on hand, but my better half would probably just write that off to me being a bit of a packrat!
Man of many hats
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
resetting toilet after new tile installed shotdown Plumbing 10 07-01-2009 10:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
