Reset Sequence For AO Smith ProMax? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2010, 10:14 AM   #1
Question
Reset Sequence for AO Smith ProMax?
My barely over a year old ProMax gas water heater is in shutdown mode. I had called a plumber and he kindly mentioned that there is a reset sequence to "disable" the shutdown mode and possibly get the water heater operational again. Is anyone familiar with this reset sequence? Thank you.
howie61 is offline   Reply With Quote
Old 03-17-2010, 11:03 AM   #2
See if this helps http://s3.pexsupply.com/manuals/1253..._PROD_FILE.pdf check the trouble shooting section.
hayewe farm is offline   Reply With Quote
Water heater reset tripped. rjniles Electrical 2 12-26-2009 09:44 AM
Boiler needs to be reset Chris12047 HVAC 8 11-12-2008 02:28 PM
HEIL furnace keeps kicking off reset switch sunsetacres1318 HVAC 8 11-04-2008 08:35 AM
Oil burner won't kick on, have to push reset edski HVAC 4 11-06-2007 02:04 PM
GFCI wouldn't reset, now it will sherlock Electrical 4 10-18-2005 10:13 AM
