Reseal ABS Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2008, 10:23 AM   #1
Rewards Points: 518
Reseal ABS fitting
About 2 years ago I was finishing my basement. In my closet, there is a black APS pipe for the sump that runs up the wall. At the bottom of the floor, there was a fitting that was sweating. At the time I thought it was PVC and not ABS. I could not get the pipe off as the fitting is cemented around into the foundation. I simply put two coats(let the first dry) of PVC cement around it to seal it from the outside. A few months later it was still not leaking, so I drywalled around it and forgot about it. I just had a sump flood and it reminded me of this pipe. When I removed the carpet in the closet, the fitting I sealed around was showing no signs of leakage on the floor where it had originally leaked prior to drywalling. I just want to know if what I did will continue to work or eventually fail since I sealed around it and used the wrong pipe cement.
n0c7 is offline   Reply With Quote
Old 05-27-2008, 11:31 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I don't really understand... is the fitting sweating or is it leaking?
Normally you don't use cement on the outside of a fitting anyway.
Journeyman Plumber
Old 05-28-2008, 09:54 AM   #3
Registered User
Termite's Avatar
This is just too easy to fix correctly.
Using PVC cement on ABS is a no-no. You must use ABS cement. To my knowledge, there is only one cement out there that can be used on both. Additionally, wiping cement on the hub of the fitting where it joins the pipe is a band-aid fix at best. Since the pipe is subject to a certain amount of pressure from the sump pump, the connection needs to be correctly made and glued using pipe cleaner and then cement.
I'd suggest cutting out the fitting and replacing it and a small section of the pipe as necessary.
Old 05-28-2008, 03:59 PM   #4
Rewards Points: 518
After reconsideration, when I have some time I will get back in the wall. The only thing is I believe the fitting was really low to the concrete so I'll have to leave as much excess as possible left over so I can actually attempt to install a new fitting on it. What kind of glued type fitting do you recommend for inside a finished wall?
Old 05-28-2008, 04:00 PM   #5
Rewards Points: 518
I say sweating as in a small amount of water "leaking" out from the fitting seal, but not an actual puncture causing a leak, caused by a poorly sealed fitting.
Water meter fitting leaking LanterDan Plumbing 6 04-02-2008 10:39 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 02:01 PM
Leaking Sink fitting seajay590 Plumbing 3 09-13-2007 08:28 PM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 07:03 AM
