Rerouting Water Pipes, Is This Way Ok? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2013, 09:02 PM   #1
Rewards Points: 117
rerouting water pipes, is this way ok?
Hi all, attached is a depiction of what I want to do. Left is the original wall with the yellow lines depicting 2 water pipes (one hot, one cold) inside the wall. These pipes go to supply water to a washroom on the 2nd floor. On this wall, I want to create an opening as indicated on the right image. To do this, is it ok for me to reroute the pipes as shown on the image? This is the easiest way I can think of.
Thanks!
jsunsun is offline   Reply With Quote
Old 05-30-2013, 09:09 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 556
45's instead of 90's would be better- but 90's will work too
The Following User Says Thank You to TheEplumber For This Useful Post:
Windows on Wash (05-30-2013)
Old 05-30-2013, 09:33 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,454
yep
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 05-30-2013, 09:34 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
Fine.
More turns = more impedance to flow so gradual turns are better.
The Following User Says Thank You to Windows on Wash For This Useful Post:
MTN REMODEL LLC (05-30-2013)
Old 05-30-2013, 09:51 PM   #5
Rewards Points: 117
Great thanks so much! I'll try to make it 45 degrees then!
The Following User Says Thank You to jsunsun For This Useful Post:
TheEplumber (05-30-2013)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 09:53 AM
