Rerouting Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2013, 11:39 AM   #1
Rewards Points: 242
rerouting pipes
Hey all. Attached is a picture of the current set up. The pipe closest to the camera is a bathroom sink drain and a vent pipe. The pipe furthest away is a toilet. I'd like to re-fit this so that the vertical pipe is a little closer to the wall. It's already closer at the bottom and I'm looking to do the same at the top. The closest pipe is Cast Iron connected with a fernco. I don't have access above the floor so I need to do the work here. Could I possibly switch the ABS 90 with a shorter 90? If not can anyone suggest any other ideas? Reconnected the toilet flange to the new pipe doesn't seem to be a challenge.
Thanks!
Lemkie is offline   Reply With Quote
Old 03-08-2013, 03:28 PM   #2
Rewards Points: 242
Anyone?
Old 03-08-2013, 04:28 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 792
The 2 90's are about as tight as you can get. There is not a smaller radius 90
Old 03-08-2013, 04:42 PM   #4
Rewards Points: 242
This is unfortunate, but thanks for confirming
Old 03-08-2013, 05:05 PM   #5
Roofmaster
Rewards Points: 2,210
use 45's commonly know as 1/8th bends. Use one street 45 and a regular 45 you can make any angle you need, then y and 1/8th bend into the main from the other fixture.
tree roots and orangeburg pipes xerxes2001 Plumbing 3 04-07-2012 08:26 PM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
