Rerouteing Drain Line From Kitchen - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2010, 05:02 PM   #1
rerouteing drain line from kitchen
I live in a 1926 house on a hill with septic tank below. The kitchen drain line is defunct and not acessible. I ran a 2" line under concrete to outside and down side of yard (above ground) . What is the los angeles code for running a drain line above ground? The inspector said it needs to be U.V.rated. I cannot find that product. It would be very hard to bury pipe since it is next to stairs and a fence with concrete posts. Thanks , Errol
errolnavickas is offline   Reply With Quote
Old 10-25-2010, 06:14 PM   #2
Rewards Points: 150
I don't know what the code is where you live about burying the pipe, but you can't leave pvc exposed to the sun, ultra violet rays. It needs to be painted or below the ground, the sun will destroy it
braindead is offline   Reply With Quote
Old 10-25-2010, 07:56 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
cast iron is excepted above ground and exposed.
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Clogged Drain line Ruski Remodeling 2 06-24-2009 07:29 AM
Kitchen drain pipe after P-trap goes UP?? pcampbell Plumbing 19 11-09-2008 04:14 PM
Installing drain line parcially upgrade. jbravo8212 Plumbing 8 02-19-2008 06:12 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
