Old 03-20-2013, 07:33 AM   #1
NCmeasure2x
Reroute help
Right side needs reroute. Help
mazac66 is offline   Reply With Quote
Old 03-20-2013, 07:38 AM   #2
Super Moderator
Reroute help
Best plan is to remove the Y -from the wall fitting using an inside cutter---these tools will fit into a pipe and cut it out of the fitting without damaging the fitting----fits into a drill---
I'll see if I can find a picture.
mazac66 (03-20-2013)
Old 03-20-2013, 07:40 AM   #3
Reroute help
Ok what is it your really trying to do?
I'm not seeing anything under there that was plumbed right.
Old 03-20-2013, 07:44 AM   #4
Super Moderator
Reroute help
Ram bit
Old 03-20-2013, 07:56 AM   #5
NCmeasure2x
Reroute help
Great advise. I put a pipe in center of drain for reference. Also a disposal will be on the left. How would yo plumb the correctly? I will use advice and cut inside of pipe and start again. Thank u all for reading.
Old 03-20-2013, 08:39 AM   #6
Reroute help
http://www.bing.com/images/search?q=...lectedIndex=82
Old 03-23-2013, 08:46 AM   #7
Super Moderator
Reroute help
Typically, I will remove the Y coming out of the wall---then install the two P-traps and the tail piece on the strainer basket---
If there is a garbage disposer---loosen it enough to turn it,if needed---
I will then aim the P-traps at the drain opening ---figure out what combination of T- ---Street 45s or 9os that will give a nice neat installation.
In our area, dish washer drain can not be installed into the garbage disposer---so I have the entrance in the tail piece.
The vacuum breaker Joe showed is not required here--just a high loop in the dish washer drain line---just under the bottom of the counter top----
Old 03-23-2013, 11:13 AM   #8
call me E
TheEplumber's Avatar
Reroute help
I must be missing something. Why not just turn the ptrap to line up with the basket strainer.
On the left side- hang the disposal and use a continuous waste disposal kit to connect to the right side. Or double trap it.
I don't see why the wye needs to go.
Need to reroute sink trap Total Tool Plumbing 2 12-04-2011 08:35 PM
Adding support to a wall, need to reroute waste pipe and more sdrzewic Building & Construction 2 08-23-2010 01:16 PM
Cutting the main pipe off my well to reroute? mattsonberg Plumbing 3 06-18-2010 10:24 PM
Want to reroute ducting.... bcbud3 HVAC 5 02-03-2010 04:02 AM
Need advice on plumbing reroute Milauskas Plumbing 9 06-22-2009 11:22 PM
