-   -   Reroute help (http://www.diychatroom.com/f7/reroute-help-175010/)
mazac66 03-20-2013 07:33 AM
Reroute help
1 Attachment(s)
Attachment 67668
Right side needs reroute. Help
oh'mike 03-20-2013 07:38 AM
Best plan is to remove the Y -from the wall fitting using an inside cutter---these tools will fit into a pipe and cut it out of the fitting without damaging the fitting----fits into a drill---
I'll see if I can find a picture.
joecaption 03-20-2013 07:40 AM
Ok what is it your really trying to do?
I'm not seeing anything under there that was plumbed right.
oh'mike 03-20-2013 07:44 AM
https://encrypted-tbn2.gstatic.com/i...zznnRVgY_cYHbdRam bithttp://www.diychatroom.com/data:imag...m+/YQpHNCEH//Z
mazac66 03-20-2013 07:56 AM
Great advise. I put a pipe in center of drain for reference. Also a disposal will be on the left. How would yo plumb the correctly? I will use advice and cut inside of pipe and start again. Thank u all for reading.
joecaption 03-20-2013 08:39 AM
http://www.bing.com/images/search?q=...lectedIndex=82
oh'mike 03-23-2013 08:46 AM
Typically, I will remove the Y coming out of the wall---then install the two P-traps and the tail piece on the strainer basket---
If there is a garbage disposer---loosen it enough to turn it,if needed---
I will then aim the P-traps at the drain opening ---figure out what combination of T- ---Street 45s or 9os that will give a nice neat installation.
In our area, dish washer drain can not be installed into the garbage disposer---so I have the entrance in the tail piece.
The vacuum breaker Joe showed is not required here--just a high loop in the dish washer drain line---just under the bottom of the counter top----
TheEplumber 03-23-2013 11:13 AM
199 Attachment(s)
I must be missing something. Why not just turn the ptrap to line up with the basket strainer.
On the left side- hang the disposal and use a continuous waste disposal kit to connect to the right side. Or double trap it.
I don't see why the wye needs to go.
