Reposition Bathroom Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2012, 03:46 AM   #16
jxr
Originally Posted by TheEplumber View Post
I didn't realize a drawer was there. I have done something like this for handicap compliance cabinets.
Female end goes to the lav, other end goes to the trap that is turned sideways- against the wall. You may have to custom build one using pvc or abs and glue fittings
After playing around this is what my plan is. I'm going to just put together something in your photo. I have black 1 1/2" (what I think) is pvc from H.D. Hope this stuff is okay to use? Here are some shots. I have to get a new trap piece to replace the glued 1 1/2" to 1 1/4" reducer, but other than that I think I'm good to go. Also I think I need to get an adapter for the last elbow with a lock nut to the size of my drain pipe right? Thanks again for all your guys help.
jxr is offline   Reply With Quote
Old 02-24-2012, 07:18 AM   #17
Rewards Points: 636
black pipe is abs make sure you have the correct glue and the glue is runny so if you do not want black glue on your hands or floor and it looks like you are on the right track
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-24-2012, 09:00 AM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Personally, i'd stick the vanity top on there and see how much room if any there is for a p-trap if you roughed that drain in above the drawers. If there's room for it, that would be the better option.
Journeyman Plumber
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
framing around drain pipe in basement griffinst Carpentry 5 03-25-2011 06:34 AM
Bathroom Sinks do not line up with drain pipe - what do I do? mark2741 Plumbing 7 04-15-2010 07:11 PM
