Reposition Bathroom Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2012, 03:00 PM   #1
jxr
Reposition bathroom drain pipe
I've been going through a full remodel. I've done everything from flooring to electrical. I haven't done any plumbing yet short or replacing the toilet flange and surrounding subfloor.
My question is what do people do when you buy a vanity and the sink location is different. I purchased a two drawer ikea vanity. That being said the drain runs right into the middle support for the cabinets. I'm curious if I'm able to somehow rotate or move it to work. I called Lowes to see if they could point me in the right direction. They told me that its not easy and it would be dissasteriss to attempt it myself. I'm very confident with my ability to learn new skills. He was just a dick and didn't want to help me one bit. Heres a couple shots. The picture of the floating cabinet is actually the vanity. I have two and ones repurposed as an entry table.
Any help is appreciated. I tryed to call my plumber buddy to give me some advice, but he's a no go today.
Thanks ahead of time.
jxr is offline   Reply With Quote
Old 02-20-2012, 06:57 PM   #2
Rewards Points: 616
cut drywall adjust pipes accordingly to fit new base, patch in drywall, finish drywall or just set base and only see it when door is open
jaydevries is online now   Reply With Quote
Old 02-20-2012, 11:57 PM   #3
you can either scribe out the center brace of vanity so the pipe has room to come through and your able to attach the rest of the drain as needed. or cut the sheet rock then the drin and re-rout to where you need. next job "sheet rock" yeah!!!!!
wildrush01 is offline   Reply With Quote
Old 02-21-2012, 03:16 PM   #4
jxr
If I have to cut out a lot of drywall I think I would like to go with a different option. Are sinks supposed to be directly above the drain? Can you not have a pipe at an angle from the sink to the drain?
Could I just run a new drain up the wall from the crawlspace?
Old 02-21-2012, 03:30 PM   #5
Rewards Points: 616
do not have to cut a lot of drywall the one i did a few weeks ago just cut a foot square out a lot more work crawling in crawlspace adding new drain then making sure it is vented correctly and then removing other drain
do not understand second ?
and you can put a 45 or 90 on pipe coming out off wall to help sink if that is what you meant on 3 rd ?
if you do choose to cut drywall and not sure what is needed to adjust for new sink take pic of exposed pipes and post and someone will help
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
Old 02-21-2012, 03:31 PM   #6
Rewards Points: 616
and let use know where you want the new drain to be versus where it is now
Old 02-22-2012, 02:49 PM   #7
jxr
My last reply was terrible, so I'm going to take some time on this one
I want to position the drain on center with the left drawer. I don't think I can modify my vanity to fit because scribing out the center support won't allow the drawers to function.
I'm ready to just cut some drywall and modify the pipe... ...
Unless there is some way I can just put an elbow on the current pipe and run it parallel to the wall and then another elbow out away from the wall?
I believe there is atleast one stud in between the old position in the new position.
Old 02-22-2012, 03:08 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 350
Do you know where the drain stack is in the wall? I don't install mine lined up to the sink, usually to the stud bay to the left or right. This way my vent will not conflict with the electricians vanity lights or a recessed med. cabinet. You may luck out and find your stack right where you need it. What will you do with the water supplies?
Worse case- open the wall and re-plumb as needed. BTW- my code allows me to put 90's on the trap arm as you propose.
Old 02-22-2012, 03:58 PM   #9
jxr
Never even thought of that. Can I acurately locate the position of the drain from the crawl space in refference to the the wall or do I need to cut a strip of drywall?
I was just planning on running a little bit longer hoses for now.
So can I do this. (1) Take off the trap and run a elbow parrellel to the wall (this is the get around the supply. (3) Run pvc over to the location and secure it to the wall and install a trap. (4) Run a elbow up to the sink. It sounds crazy to me, but I figured I would ask. I know its not proper to have a gerbal farm full of pvc.
Old 02-22-2012, 04:14 PM   #10
Plumber
Rewards Points: 350
In the crawl- measure from hw pipe to vertical waste pipe. It typically drop straight down the wall.
You could als grap the trap,wriggle it and see if you can tell where it comes from- horizontal or vertical.
OK. but will the valves hit the cabinet? And will they be accessible?
You're right it is crazy. Better to do the work in the wall, behind the cabinet. My boss would fire me for that kind of work and the inspector would fail it
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (02-22-2012)
Old 02-23-2012, 04:25 AM   #11
jxr
Is it okay to rotate the trap? I was trying to see if there was anyway that the current piping would work.
Old 02-23-2012, 08:27 AM   #12
DIY staff
Rewards Points: 7,174
Trap must be attached to the tail piece of the sink---never down line from the sink--
In a word---NO---
Old 02-23-2012, 10:12 AM   #13
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How the heck do they expect you to hook that up with drawers in the way?
Is that cabinet actually intended to be used as a vanity?
Journeyman Plumber
Old 02-23-2012, 07:07 PM   #14
jxr
Yeah it actually is. It's from Ikea called a godmorgond or something. We got the base cab for 75 so I figured it was worth the work plus it's really the look we wanted.
Anyways it's meant for a really shallow drain. The drawer isn't very deep and it has a box that is much smaller than the face. As long as I can get the trap inside the drawer I can modify the drawer if needed. Also if one of the drawers space is halted that's okay.
Old 02-23-2012, 08:12 PM   #15
Plumber
Rewards Points: 350
I didn't realize a drawer was there. I have done something like this for handicap compliance cabinets.
Female end goes to the lav, other end goes to the trap that is turned sideways- against the wall. You may have to custom build one using pvc or abs and glue fittings
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
jaydevries (02-23-2012), jxr (02-24-2012)
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
framing around drain pipe in basement griffinst Carpentry 5 03-25-2011 07:34 AM
Bathroom Sinks do not line up with drain pipe - what do I do? mark2741 Plumbing 7 04-15-2010 08:11 PM
