Old 12-06-2004, 02:46 PM   #1
Default replumbing an old house
I have bought an old house with a lot of land at a good price, so it goes unsaid that I also have a lot of work to do on it. The idiots that owned the home before me screwed up a lot of things trying to fix them. I have old steel pipe for my water lines right now, some of them look like tree bark where the pipes have rusted, and flaked. No leaks from them yet, but there is a leak somewhere. In the bathroom that they added, it looks like they had a box of elbows and t's and were just trying to use up all of their supplies or perhaps just trying to fill in all of the area under the bathroom. I have lines running in every direction, and back again then over up and back again. It is crazy. I have never seen anything like this. The house needs leveled, but I don't dare set a jack under it until the old pipes are replaced. I have decided to redo the whole house. I believe the leak is underground off of the main going over to the faucet, but instead of digging up all of that dirt, I am going to just dig a trench from the box, up to the house, set an outside faucet by the steps instead of over at the side of the house. I guess what I reallly want to know, is this, is 1" pipe coming into the house, reduced to 3/4 branching to the bathrooms, and reduced to 1/2 coming up through the floor the norm? Is that where I will get my water pressure? and should I bring the main up out of the ground as soon as I get under my pier and beam house? I have two bathrooms, two outside faucets, a washer, and the kitchen, 42 feet from the box to the house, another 25 feet to our bathroom, then elbow over another 30 feet to get to the guest bathroom where the water heater is. Will 1" pvc suffice for this situation? thanks
simonfrog is offline   Reply With Quote
Old 12-06-2004, 09:02 PM   #2
Originally Posted by simonfrog
I have old steel pipe for my water lines right now, some of them look like tree bark where the pipes have rusted, and flaked. I have lines running in every direction, and back again then over up and back again. It is crazy. I have never seen anything like this. I guess what I reallly want to know, is this, is 1" pipe coming into the house, reduced to 3/4 branching to the bathrooms, and reduced to 1/2 coming up through the floor the norm? Is that where I will get my water pressure? Will 1" pvc suffice for this situation? thanks
How's your water pressure now? Are you on a well or is it a public supply?
The house I grew up in was built in the 40's by a couple of farmers and it has plumbing just like you describe. In fact, the water pipes actually "loop" through the house - that is to say they do not dead end anywhere. When I was a kid the house had a well / pump that barely kept up - now it has 'city' water with plenty of pressure. I'm guessing the water piping schematic had something to do with optimizing pressure at the fixture.
I've seen sprinkled (fire suppression) townhouses serviced by 1" tubing. I can't imagine it's not enough for your needs.
pipeguy is offline   Reply With Quote
Old 12-11-2004, 12:33 AM   #3
Contractor
Your problem may be internal. I spent some time as an engineer for a large municipal utilities system and one of the things that really sticks in my mind was a street on a 3/4" water main that was visible along the driveways and as it was being replaced we discovered that the scale buildup had reduced the interior diameter to that of about a pencil! Imagine servicing a dozen homes through a 3/8" waterline! That was what was going on.
Something to look into.
Teetorbilt is offline   Reply With Quote
Old 02-09-2005, 01:06 AM   #4
1" pipe should be sufficient A couple of things to keep in mind...reducing the size of a pipe increases the speed of the flow, it does not increase the pressure. The way to increase pressure is to restrict the flow. You will experience pressure drop when running long runs of whatever size pipe you use.
Tomm is offline   Reply With Quote
Old 05-29-2009, 07:37 PM   #5
011000100110111101101111
DangerMouse's Avatar
hey timberland, this is a DIY site, you _____!
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
DangerMouse is online now   Reply With Quote
Old 05-29-2009, 07:44 PM   #6
Extreme DIY Homeowner
Scuba_Dave's Avatar
Digging up a 3 year old thread
That's not spam?
Brain not working?
Scuba_Dave is online now   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip we will be diagnosing our problem. We have a bathroom here that is set up with an older style faucets, now over the years this faucet has develop a leak which has gotten progressively worst... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and today we are replacing the hot water pipe and valve. Now we’ve already installed the valve, which is a two outlet valve- one for the sink and one for... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking all of our exterior faucets. First off you want to make sure that you disconnect all hoses so that they don't freeze and cause a pipe to break. The next thing I'll do is I... Read More »
We did here in our houses. We have the good insulation but it was not good enough for me. So when we got all these packages from the company's with all these Styrofoam chips in there, we used these chips and put them on top of the ceiling and add to the... Read More »
A tank like this cost you about $1,500 including the pipes, including the faucets and everything you want to use for it. We will just follow now the line of this rain water, how it comes into our house, and you can see how we use it. So what you see here... Read More »
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 07:54 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 13 08-03-2007 09:48 PM
Re-siding house jdig Building & Construction 5 04-10-2007 11:15 AM
Will my house make my kids sick??? jokrupinski General Discussion 18 09-29-2006 06:05 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 04:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
