Old 06-14-2011, 10:12 AM   #1
Replumbing house -- Proper Order of Operations?
Hi All, I am replumbing my entire house, planning on using PEX. I am on a well and will be installing a new tankless water heater and whole house filter. I guess I want to make sure that when it comes to the flow of the water from the well to the faucets that it goes through each element in proper order (if there is one). Here is my original thought, starting with the well: 1) Water pump (obviously) 2) Pressure tank 3) Whole house water filter 4) Hot water heater 5) PEX manifold 6) Water lines, Faucets, etc. Does that seem about right, or should I re-arrange anything? Thanks! tom
tomackey is offline   Reply With Quote
Old 06-14-2011, 10:20 AM   #2
Doing it myself
Alan's Avatar
Seems just fine to me. . . what are you waiting for?
Journeyman Plumber
Alan is online now   Reply With Quote
Old 06-14-2011, 10:36 AM   #3
...finishing other renovations around the house. Thanks, Alan!
Old 06-14-2011, 05:58 PM   #4
Homerepairguy's Avatar
A logical way of looking at the proper sequence would be to replace lines so new lines always feed old lines. Doing it in reverse could allow crap from old lines into new lines. Opening downstream faucets all the way and removing and cleaning aerators in spouts can help if small crap gets dislodged from old pipes during your work.
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
tomackey (06-16-2011)
Tags
filter, hot water heater, pex, plumbing
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 12:43 PM
Weird wiring in house fdmillion Electrical 7 02-26-2010 01:57 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
Order of operations? cevamal Painting 2 09-14-2009 11:43 AM
