Replcing Thermocouple On Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2010, 11:40 AM   #1
replcing thermocouple on hot water heater
my hot water heater will not stay lit, i have to relight pilot over and over to get water hot, once hot, the heater turns off and does not relight again.
the existing thermocouple has a diffedrent feature than the replacement one. is that normal?
kingjames is offline   Reply With Quote
Old 02-28-2010, 12:30 PM   #2
Rewards Points: 1,016
Not sure what you mean by different feature?
Old 02-28-2010, 03:16 PM   #3
Is this a Whirlpool water heater? If so, there is a known issue with the valve causing the problem you describe. If you contact Whirlpool they may replace the valve for you.
Mike in Arkansas is offline   Reply With Quote
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
