Replacing Wax Ring On Toliet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2010, 06:25 PM   #1
Replacing wax ring on toliet
My toliet starting leaking, so i took the toliet off and notice the wax ring was hardly smashed at all. The flange is not even will the tile flooring in the bathroom. I went out and bought an extra think flange and tried putting that on. When i place the toliet back on the extra think wax ring showed more displacement but not enough that i feel it will be a tight fit. What can i do to in sure a tight seal. I have heard you could use 2 wax rings will this work, or do i need to try something else?
gocats1245 is offline   Reply With Quote
Old 01-25-2010, 06:57 PM   #2
I've had success using two. I like to get one regular wax ring and one wax ring with "horn" (kind of a plastic funnel). I place the regular wax ring on the floor flange first, then the ring w/horn on top of that. then carefully set the toilet down on that. Gently twist the toilet to seat it on the floor - don't rock.
Ishmael is offline   Reply With Quote
Old 01-26-2010, 07:28 AM   #3
A few months back one of the contibutors here on the DIY chatroom showed us the very best method for installing wax rings including pictures. I thought it was so great I included it on my blog site and have republished it several times making ssure to give him the credit for it. Here is a link to my blog and further info on the process and the pics:
I hope this helps.
faucetman886 is offline   Reply With Quote
Replacing Metal Ring Around Garbage Disposal in Sink julbox3134 Plumbing 2 09-15-2009 01:19 AM
closet ring flange help/explaination eyeglass Plumbing 2 09-09-2009 06:35 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
Toliet Wax Ring Dilemma myworkshop Plumbing 7 05-05-2009 10:34 AM
rocking chair or toliet? kahnegirl Plumbing 6 01-16-2009 11:29 PM
