Replacing A Water Valve To Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2011, 05:25 PM   #1
Replacing a water valve to toilet
I need to replace the water valve to our toilet. There is a compression fitting on the copper tubing and I can't get the old compression ring off. What do I do?
tortvet is offline   Reply With Quote
Old 01-14-2011, 05:29 PM   #2
Cut it off with a pipe cutter. Clean up the pipe with some very high grit sandpaper until it is nice and smooth and round.
You can then replace with new compression fitting or solder a new one( better IMO).
Make sure you turn off the water before you start.
MoldyJay is offline   Reply With Quote
Old 01-14-2011, 05:33 PM   #3
If I cut it off, it will make the copper pipe too short to be able to attach the new valve!
Old 01-14-2011, 05:41 PM   #4
Have you tried a dremel to cut the ring?
Old 01-14-2011, 05:42 PM   #5
Nevermind probably squashed on good. You may need to take off some drywall so you can add a new section of pipe.
Old 01-14-2011, 05:48 PM   #6
I thought about that but I am afraid of damaging the copper pipe in doing so. I may have to try it. Thanks
Old 01-14-2011, 05:52 PM   #7
Homerepairguy's Avatar
Rewards Points: 990
Never tried it myself but this "might" work (uses the heat expands, cold contracts principle):
Put a rag or paper towel in some ice water. Heat the brass compression fitting with a pin point propane torch or even maybe a match or lighter. While still hot, wrap the cold rag around the copper pipe (not the compression ring) to try to shrink the copper pipe. Use a pliers to try to rotate the ring without nicking the pipe.
HRG
Homerepairguy is offline   Reply With Quote
Old 01-14-2011, 06:04 PM   #8
Man, I just reuse the old nut and ferrule and screw the new valve on. It usually works.
broox is offline   Reply With Quote
The Following User Says Thank You to broox For This Useful Post:
VIPlumber (01-14-2011)
Old 01-14-2011, 09:52 PM   #9
I do the same as Broox.
VIPlumber is offline   Reply With Quote
Old 01-14-2011, 11:44 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 346
Me too. Or I use a ferrule puller.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Replacing Dishwasher - Water Valve Help? BCreed025 Plumbing 1 07-26-2010 05:01 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
