Replacing Washer Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2012, 11:36 PM   #46
Yeah I triad everything in my power to get it exactly how you said but the hole was already in the ceiling for the vent and I didn't want to try and move it.. I tested everything out and ran the washer on a super load and ran the sink at the same time and it ran beautifully and didn't even gurgle or hiccup. I also triad to put the stand hose pipe at 20" and my father and law was all like that's to high blah, blah, blah, lol. I did get it at 17 and since it started at 13 I was comfortable with it haha
robertkirkland is offline   Reply With Quote
Old 08-11-2012, 11:59 PM   #47
Rewards Points: 616
i would suggest putting new trap on a t below the sink drain so when the wash machine pumps water it will not come up in sink
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 08-12-2012, 12:30 AM   #48
Yeah so far so good, but I plan on redoing the entire sink to PVC once I get the time and money to tear out the old sink and get a new countertop and cabinets and what not. I'm just glad I did this entire project for only 130 dollars
Old 08-12-2012, 01:30 AM   #49
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That's the wrong type of fitting for that application.
http://www.terrylove.com/images/abs/...ture_cross.jpg
Journeyman Plumber
Old 08-12-2012, 01:32 AM   #50
Care to elaborate on that Alan?
Just seen your pic. That's the only double t that home depot had anyways and looked exactly like the double t that came off the pipes in the first place bit its working so I'm jot complaining haha
Old 08-12-2012, 11:18 AM   #51
Doing it myself
Alan's Avatar
The reasoning behind it is that if you ever have to snake it through the fixture's trap arm that it will go down the drain instead of straight across into the other fixture.
Journeyman Plumber
Old 08-12-2012, 11:21 AM   #52
Oh ok I see
Washer Drain Hose ? calebm12 Plumbing 2 07-09-2012 10:43 PM
Washer Drain Overflows ryanb4614 Plumbing 2 03-21-2012 12:12 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
