Replacing Washer Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2012, 11:16 PM   #31
Rewards Points: 630
that looks good to me use 2 " for all pipe
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 08-08-2012, 11:28 PM   #32
i dont have enough room in the wall to do that 6' from where T is,is where the wall ends. can i flip the T and move the AAC over some.
and thanks for sticking with me on this lol
robertkirkland is offline   Reply With Quote
Old 08-08-2012, 11:30 PM   #33
should i use a compression adapter for the hose also?
Old 08-08-2012, 11:42 PM   #34
Rewards Points: 630
compresoin is optional and i would not change t but instead reduce the 6 " piece of pipe i like atleast that to make it easy to get a snake through if ever needed but they can just take aav off and snake through there
Old 08-08-2012, 11:45 PM   #35
Rewards Points: 630
most of the time my t ends up in one stud space then i drill through stud put pipe through and then p trap in next stud space. if covering up with drywall use a cold air grill in front of aav so it can breath and be excess able
Old 08-08-2012, 11:45 PM   #36
So instead of having the cleanout there put a 90 degree elbow there?
Old 08-08-2012, 11:49 PM   #37
Rewards Points: 630
it should look like this pic no clean out needed use a glue p trap
Old 08-09-2012, 12:07 AM   #38
Ok cool. Thanks for all your help Jay I really appreciate it
Old 08-09-2012, 10:28 AM   #39
Doing it myself
Alan's Avatar
Rewards Points: 2,086
FYI : my local rules regarding washing machine installation
Trap for clotheswasher standpipe shall be roughed in no less than 6" but no more than 12" above the floor.
Standpipe for washing machine shall be no less than 18" long, but no more than 30" long
The trap arm (between the trap weir and the vent) shall be no less than 2X the diameter of the pipe. (IE : 2" pipe = 4" trap arm)
There's nothing wrong with the way you have it drawn here : replacing washer drain pipe
Other than you keep referring to it as AAC, when it's actually an AAV, or some refer to them as Studor vents. Just didn't want you to have a hard time finding what you need.
Drain must be 2", the vent can be 1-1/2"
Don't get a trap with a cleanout in the bottom of it... it's not really necessary. If you want a cleanout, put an extra sanitary tee in the drain portion below the vent tee, and put a cleanout adapter in it.
Journeyman Plumber
Old 08-09-2012, 11:52 AM   #40
Alan thanks for your insight I will keep that in mind. And yeah I figured out I was going by the wrong abbreviations last night looking at prices lol
Old 08-11-2012, 10:08 PM   #41
So I just wanted to post an update here is the finished product don't mind the wall haha. That's tomorrows project
Old 08-11-2012, 10:19 PM   #42
Rewards Points: 630
pic did not post
Old 08-11-2012, 10:25 PM   #43
I noticed sorry here it is, let me know what you think haha
Old 08-11-2012, 10:49 PM   #44
Rewards Points: 630
ok what is the pipe on the left connected to and the top of the double t (cross) goes to aav and will be accessible
Old 08-11-2012, 11:05 PM   #45
Come to find out that that is the sink drain. The extra pipe I seen under the house went to a old ac unit drain. The vent to aav is the top of the double t
Washer Drain Hose ? calebm12 Plumbing 2 07-09-2012 10:43 PM
Washer Drain Overflows ryanb4614 Plumbing 2 03-21-2012 12:12 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
