Replacing Washer Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2012, 09:25 PM   #16
Rewards Points: 616
the real problem is probably a clogged pipe but you should have a trap on the pipe then when you add the trap then you need to vent it
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 08-08-2012, 09:27 PM   #17
How much is a trap. And you have to vent it out the roof right?
robertkirkland is offline   Reply With Quote
Old 08-08-2012, 09:46 PM   #18
Rewards Points: 616
the best thing to do is to remove galvanized pipe from cast which is leaded into the cast bell. use 2" pvc pipe and use a cast donut to seal into cast bell run 2" with a 1/4 " per 1' fall supporting every 4 ' then turn up with 90 the put a sani tee with top going above flood rim of wash machine i like at least 10". then out side off sani tee with at least 6 " of pipe then a trap with i like at least a 20" piece of pipe then wash hose goes into it
like pic but with just one horizontal pipe with trap
since could not get pic to load try this link
http://www.ask.com/wiki/Air_admittance_valve
Old 08-08-2012, 09:52 PM   #19
Rewards Points: 616
so this is a wash machine rough in only thing you would do different is the vertical vent pipe right of wash box would have an aav (air admittance valve) i like 10" above wash box or wash machine stand pipe
Old 08-08-2012, 09:54 PM   #20
Rewards Points: 616
also t and trap would be above the floor
Old 08-08-2012, 09:56 PM   #21
So the sani tee would connect to the top above the floor and the trap would go off the side of the sani tee right?
Old 08-08-2012, 10:08 PM   #22
Rewards Points: 616
yes and you might have to go to plumbing warehouse to get donut there is a heavy wall and regular wall cast so you if the donut does not fit with 2 "pvc in it it might be wrong donut
http://198.65.243.132/Stores_Tools/H.../tools800.html
Old 08-08-2012, 10:20 PM   #23
the donut is just a rubber piece that sticks over the end of the cast bell and and you insert the pvc piipe into it right? and does the vent need to go out the ceiling i just had the roof and siding on the house replaced and dont want to mess that up if possible?
Old 08-08-2012, 10:32 PM   #24
so this is pretty much how it should look when im finished right?
Old 08-08-2012, 10:40 PM   #25
Rewards Points: 616
no the donut goes into the cast iron bell to replace the leaded in galvanized pipe
here is a vidio of how you lead in a pipe so you can see what you have to do in reverse to get lead out from around galvanized pipe but instead of repouring lead you will use donut
http://www.constructionlounge.com/ho...our-joint.html
Old 08-08-2012, 10:46 PM   #26
Rewards Points: 616
yes top off t would go at least 10 " above wash machine stand pipe then install a.a.v.
here is good video on how an aav works
http://www.youtube.com/watch?v=-yI7n...feature=relmfu
Old 08-08-2012, 10:56 PM   #27
could you fix my picture and show me excatly where i would put the T at i dont want to mess this up lol
Old 08-08-2012, 11:11 PM   #28
Rewards Points: 616
t is correct just wanted to make sure you knew where to put aav at
Old 08-08-2012, 11:14 PM   #29
how would this work out?
Old 08-08-2012, 11:14 PM   #30
Rewards Points: 616
except where you have the 90 coming off of t it should be at least 6' of pipe then a glue trap then i like at least a 20 " stand pipe to put wash hose in
Washer Drain Hose ? calebm12 Plumbing 2 07-09-2012 10:43 PM
Washer Drain Overflows ryanb4614 Plumbing 2 03-21-2012 12:12 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
