Replacing Washer Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2012, 02:42 PM   #1
replacing washer drain pipe
ok so i have a 1 1/2 inch pipe which is to be used for draining the washer to the main drain pipe. it backs up everytime i try to use it, i just use the kitchen sink which i hate. i have heard that washers now a days need a 2 1/2 inch pipe to drain from. so i am going to replace the old cast iron pipe with pvc pipe i just need to know how to remove the old pipe from the main drain pipe i will post pics any help would be appriciated
robertkirkland is offline   Reply With Quote
Old 08-08-2012, 04:26 PM   #2
I meant replacing the washer pipe... anyone???
Old 08-08-2012, 06:33 PM   #3
Rewards Points: 630
i see on the side of the cast bell it is stamped 2 so the cast is for a 2 " so lets start by asking for a pic of trap
1 what is pipe length coming out of trap to wash hose
2 the length from trap to cast bell
3 the outside width of the galvanized pipe that is coming out of cast bell
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
robertkirkland (08-08-2012)
Old 08-08-2012, 06:37 PM   #4
Originally Posted by jaydevries View Post
i see on the side of the cast bell it is stamped 2 so the cast is 2 " so lets start by asking for a pic of trap and what is pipe length coming out of trap to wash hose
Ok I'm sorry I'm no plumber and I hope you can bear with me. Yes it is a 2 inch leading to the main pipe bit if I'm not mistaking its a one and half inch at the elbow going into the floor. Where would the trap be located at all I seen was the big pipe it's connected to goes straight thru the ground. Thanks for replying by the way
Old 08-08-2012, 06:37 PM   #5
the Musigician
DangerMouse's Avatar
I was wondering about that.... fixed it for you.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 08-08-2012, 06:38 PM   #6
DM
Haha thank you!
Old 08-08-2012, 06:40 PM   #7
Rewards Points: 630
the trap should be located near where the wash hose goes into pipe if you do not see one take a farther back pic so we can see more of pipe and where wash hose goes into pipe
Old 08-08-2012, 06:51 PM   #8
That could be the problem then I am not at home to take a picture but in a sec I can get on my laptop and draw a mock up of how it looks on paint but pretty much its about 6 foot long straight pipe 1 and a half inch maybe 2 I was only going on what I was told. Then a 70 degrees elbow I think and a pipe that extends from as far as the house into that big pipe in the picture maybe 20 feet or a little shorter
Old 08-08-2012, 07:59 PM   #9
okay jay im sorry i know this paint picture isnt going to help much but i hope it at least gives you an idea of whats going on. I dont think there is a trap there anywheres but here is what it looks like, and thanks again lol
Old 08-08-2012, 08:40 PM   #10
Rewards Points: 630
where the wash hose goes into pipe is it sealed closed if it does not have a trap and it is not sealed it would be rare not to smell sewer gas occasionally
Old 08-08-2012, 08:44 PM   #11
I have never smelled sewage but I have never looked for it either. So your saying I need to add a trap to it to fix the problem
And no its not sealed either
Old 08-08-2012, 08:48 PM   #12
Rewards Points: 630
no it needs a trap and a vent and probably new pipe
Old 08-08-2012, 08:51 PM   #13
Rewards Points: 630
do you feel up to it
Old 08-08-2012, 08:51 PM   #14
About how much would a trap cost and is that something I can do myself I don't have 500 noless 1000 to shell out to have professionals do it. But I tend to think I am smart enough to do some things on my own haha
Old 08-08-2012, 09:18 PM   #15
And yes I'm most certainly up for it lol
Washer Drain Hose ? calebm12 Plumbing 2 07-09-2012 10:43 PM
Washer Drain Overflows ryanb4614 Plumbing 2 03-21-2012 12:12 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
