Replacing Vinyl Flooring With Thicker Laminate. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2012, 02:13 PM   #1
replacing vinyl flooring with thicker laminate.
Do I need to raise the toilet flange? If so how much? The new floor is approximately 1/4" above the top of the existing flange.
xms services is offline   Reply With Quote
Old 02-04-2012, 02:17 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
If the flooring is flush with the top of the flange then you can get a #10 wax ring. #10 is an extra-thick wax ring and you should be ok.
But if the flooring is taller than the flange hight thwn you may need to raise the flange to either flush with the flooring or place the flange ontop of the flooring.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-04-2012, 02:35 PM   #3
Rewards Points: 13,960
Should not be installing laminite in a bathroom.
Reason being the toilets going to hold the floor down tight to the floor. Laminite needs to float, if not it pulls it's self apart at the seams.
Old 02-04-2012, 03:23 PM   #4
Rewards Points: 560
Have you actually seen this because I haven't.
I actually installed just like this and have never had an issue.
WIth proper spacing at the primeter of the room having such a small area confined souldn't be a problem with expansion and contraction of the flooring
Trafficmaster Allure - Underlayment? HuskySkull Flooring 47 06-11-2014 04:04 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 01:59 PM
Laminate flooring questions phil74501 Flooring 8 03-04-2011 10:22 PM
