Replacing Valve Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2012, 08:54 PM   #1
Rewards Points: 49
I am replacing a valve cartridge on a Delta 1400 shower faucet. I pulled the handle off, then the outer sleeve and now I'm trying to get the collar off. I'm using channel locks, but it isn't budging. I'm worried that if I use more force that I'll twist the copper tubing. I just sprayed PB Blaster to see if it would loosen the connection, but I wanted to check to see if there were any tricks before I go further.
Any suggestions?
Cultcab is offline   Reply With Quote
Old 05-08-2012, 09:03 PM   #2
Rewards Points: 636
once in a while i get one of those they are not fun. i like a pipe wrench less likely to deform brass
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
oh'mike (05-08-2012)
Old 05-08-2012, 09:46 PM   #3
Rewards Points: 49
After I posted, I was able to get it to break free. Unfortunately, the valve unit is now crooked. I can get the sleeve back on, but there is a small gap between the sleeve and the escutcheon.
Is it safe to "gently" pull it back straight, or am I going to need to reinstall a new copper manifold?
Old 05-08-2012, 09:48 PM   #4
Rewards Points: 636
turn the water on if it does not leak you should be good
Old 05-08-2012, 09:57 PM   #5
Rewards Points: 49
Water is on - no leaks. I am going to try to pull up to straighten it out. Hopefully the copper is still in good shape after 15 years.
Old 05-08-2012, 10:15 PM   #6
Rewards Points: 636
some times you can tighten one screw and loosen other to straighten it up. usually due to lack of support on pipes and valve body
Old 05-08-2012, 11:03 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I have had too many bad experiences with those things. Whenever I see one, I go back and get a new valve to have on hand in case the repair goes south. Sounds like yours worked out well.
What a horrible design.
Journeyman Plumber
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 11:43 PM
Help replacing stem valve assembly for washing machine a12733861 Plumbing 7 01-12-2012 12:13 PM
Replacing shut off valve and I can't get it off. Any ideas? davidevan Plumbing 9 01-23-2011 02:15 PM
Need help replacing shower cartridge MrAngles Plumbing 7 03-01-2009 02:38 PM
Replacing shower valve - galvanized pipe? rjniles Plumbing 2 05-08-2008 10:29 PM
