Replacing Undersink Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2013, 01:07 PM   #1
Hello all, and thanks in advance for any help you can give.
I have a wall mounted sink in a very small half bath. The previous homeowners plumbed both the supply lines and p-trap with PVC, so I would like to replace the lines with something like this:
http://www.amazon.com/KOHLER-K-7605-.../dp/B0000B0PI4
And the p-trap with something like this:
http://www.amazon.com/KOHLER-K-8998-.../dp/B00155MSWM
What I think I need for the water lines is a 1/2" cpvc to 3/8 NPT, and just a simple PVC trap adapter for the drain.
Am I on the right track? Any thoughts on where to source the CPVC to NPT adapter?
standmatt is offline   Reply With Quote
Old 01-06-2013, 01:08 PM   #2
Rewards Points: 2,516
can you provide a picture of the current setup?
hammerlane is offline   Reply With Quote
Old 01-06-2013, 01:12 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 806
Use braided flex supply lines and a pvc trap. No need for chrome unless you want the looks.
Old 01-06-2013, 01:21 PM   #4
Picture of the Setup
Here's the overall picture of what I'm dealing with
Fullsize images here:
https://www.icloud.com/photostream/#...4-520FF805EC3B
Old 01-06-2013, 01:22 PM   #5
Agreed on the use of braid and PVC if I didn't care about the aesthetics, but since it's exposed, I do.
Old 01-06-2013, 01:55 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Install drop eared elbows in the wall and use chrome nipples to come out to the valves.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
standmatt (01-07-2013)
Old 01-06-2013, 03:27 PM   #7
Plumber
Rewards Points: 806
In that case- Cut the water stubs shorter so minimum pipe is exposed and use the angle stop of your choice. Put escutcheons on for trim.
Use chrome plated risers to the sink. You can buy a bender to form the offsets if needed.
Also you can use a chrome ptrap and tailpiece. A standard PVC trap adapter will work at the waste arm. If set back far enough, a 1.5" box escutcheon will cover the trap adapter. After doing all the above- all you'll see is chrome. It'll look sharp
Old 01-07-2013, 08:32 AM   #8
Thanks! Picked up these parts last night. This will work perfectly. I'll post pictures when its all done
TheEplumber, I was going to go the PVC route, but the angle stops I want have 1/2 in. Female NPT connections on them, and I'm wary of screwing PVC and Metal together.
Old 01-07-2013, 09:19 AM   #9
A "Handy Husband"
rjniles's Avatar
That is why I suggested a drop ear elbow with a chrome nipple.
http://www.cpesupply.com/default.asp...12CPVCBRADRO90
or any plumbing supply house
Old 01-07-2013, 07:40 PM   #10
Did anyone look at those amazon links. Is that the proper price for that stuff? WoW!
paintdrying is offline   Reply With Quote
Old 01-07-2013, 09:11 PM   #11
Thumbs up
Sorry, in the above post I tried to respond to both of you guys. I followed your suggestion, it will work perfectly, thanks!
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
A few Q's about replacing old plumbing Fisher252 Plumbing 9 01-30-2011 09:22 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
Replacing plumbing system kbsparky Plumbing 5 09-16-2008 09:41 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
