Replacing Tub Waste Stopper For Narrow Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2010, 07:17 PM   #1
Replacing Tub Waste Stopper for Narrow drain Pipe
I removed an old drain flange from my tub (thanks to the cut and chisel method I learned on this site) and wanted to replace it with a toe-operated drain plug . Unfortunately the only replacement flanges or plugs I find screw into a 1.5 inch pipe and mine is narrower (I'm guessing 1.25 inches). Also the threading isn't as coarse as on the 1 1/2 inch plugs. Does anyone know where I can find small thread on a replacement drain plug/flange?
japru is offline   Reply With Quote
Tags
drain , flange , narrow , thread , tub
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 05:19 PM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General DIY Discussions 3 09-05-2009 05:44 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
