Replacing Tub Spout After Re-tiling - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2009, 02:32 PM   #1
Replacing tub spout after re-tiling
I just finished tiling an old tub surround and the new tile plus backer board added about one inch in new thickness so the end-threaded tub spot no longer reaches the threads on the pipe coming off the wall. (See pic which doesn't quite show the pipe!) I am hoping this is a common problem (?) and there might be a simple screw-on extension or something but local Lowe's was no help. Do I need a plumber to sweat on a whole new piece or is there an easier fix?? Thanks!
BillyB44 is offline   Reply With Quote
Old 05-15-2009, 06:13 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
No pitchers showed up.
If it is a galvanized nipple, just unscrew it and get one that is one inch longer.
edit: If it is copper, just cut it back and sweat in a little longer piece.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 05-15-2009, 08:21 PM   #3
Thanks, it is galvanized pipe but could be 'frozen' in place from age. I guess I may have to just try to muscle it out and hope nothing breaks...
Old 05-15-2009, 09:24 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Working with old galvanized can be fun.
Tap the end of the pipe with a hammer (not too hard, just enough to cause enough vibration to help loosen the threads).
Use a large pipe wrench and try to turn it clockwise (to normally tighten it) to also try to break it loose.
Then spray the end in the wall with WD-40 and let it sit for a bit.
Now, turn it out with the pipe wrench counter-clockwise.
Get a 1/2" galvanized nipple one inch longer. Wrap 2-3 flat wraps of teflon tape around each threaded end clockwise as the threaded ends face you, and tighten it in. Then screw on the spout.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-16-2009, 11:50 PM   #5
Had the same problem. A six inch was too long and a four inch was too short. Went to the lawn sprinkler entensions and found all different size fiber extensions. Just right!!
Otherbill is offline   Reply With Quote
Old 05-17-2009, 06:33 AM   #6
Rewards Points: 150
nipples come in various lentghs not just 4 inch or six inch you can get a 3and a half or 2 inch whatever you need. also after you put the nipple in put caulk all around the pipe where it goes through the wall and after you install the tub spout put a bead of caulk all around the spout where it meets the wall. do the same with the handles.
al's sewer is offline   Reply With Quote
Old 05-17-2009, 06:38 AM   #7
Rewards Points: 150
should also have mentioned a tub spout does not have to be that tight as long as you get a good snug fit against the wall you will be ok. Just make sure that when you caulk you don't caulk that little notch that is on the bottom of the spout where it meets the wall.
Old 05-18-2009, 12:15 PM   #8
Interesting, thanks.
Sounds like good advice, but are you saying you didn't need to remove the old (too short) pipe from the wall and were able to just add a short extension from lawn sprinkler dept? That'd be ideal! Thanks for the grouting pointers, too...I'll be glad when I get to that stage.
Old 05-19-2009, 06:50 AM   #9
Rewards Points: 150
If its a threaded galvanized nipple you will have to remove tthe old nipple and replace with a new one. be careful working with old galvanize can be a pain.
Old 05-22-2009, 01:14 PM   #10
This is a great idea. I went to Lowe's and for .47c found a nylon sprinkler pipe extension that (by cutting it down some) lets me extend the galvanized pipe the needed 1". Much better than trying to remove and replace the old pipe. Thanks!
Old 05-22-2009, 03:45 PM   #11
HVAC / Plumbing
Is the nylon rated for hot water. Most I've seen isn't. May be a problem. May not
kenmac is offline   Reply With Quote
Old 05-22-2009, 05:08 PM   #12
Damn good question. I'll have to check that out. Seems like some sprinklers could be exposed to very hot, sunny conditions, but this bears some investigating. Thanks.
Replacing tub, tiling above J187 Remodeling 4 05-17-2009 12:19 AM
Bath tub spout leak issue abc Plumbing 1 01-26-2009 01:04 AM
Tub Spout Help showerhelp Plumbing 9 11-13-2008 07:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
Shower head not working, having trouble with replacing the tub spout keyser soze Plumbing 26 06-12-2007 07:39 PM
