Replacing Tub Hardware - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2011, 04:12 PM   #1
Replacing tub hardware
Is it difficult to replace my faucet and all hardware in my tub. It has one knob for the hot/cold water and a faucet. It. Also has a button that you push in for the water to goto the shower head. I didn't know if I should try it before calling a plumber. The button is not working anyone so you can only take a shower and not a bath. Thanks for any help.
Sackm is offline   Reply With Quote
Old 06-12-2011, 05:08 PM   #2
DIY staff
Rewards Points: 7,174
Could you clear up a thing or two?
First --the tub spout--is that where the 'push button' is to switch from shower head to spout?
Changing a tub spout/diverter can be a DIY project--however not necessarily an easy one.
Changing the mixing valve is fairly advanced plumbing and requires soldering---and drywall or tile replacement. A plumber may be needed for that is your plumbing skills are basic.--Mike---
Old 06-20-2011, 02:10 PM   #3
The push button diverter that I have now is not attached to the faucet. It's under the water knob on the wall. I took everything off and the new hardware that I bought looks easy to put on. My question is how do I take the old diverter off and can I cap it off somehow???? Thanks
Old 06-20-2011, 02:45 PM   #4
DIY staff
I'd need to see a picture or have a link to the product----What you are describing is not a common item so I can't say much without more info.
Replacing Locks on exterior door ddygert Remodeling 6 10-20-2010 07:11 PM
Replacing Moen Roman Tub Faucet - How to get out old hardware? mav1c Plumbing 1 08-09-2010 09:57 AM
Pella Storm Door Hardware Crosseyed08 Building & Construction 0 04-23-2010 07:17 PM
Bifold door hardware hel handylady Carpentry 1 10-28-2008 06:45 PM
