Replacing Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-24-2008, 12:58 PM   #1
Rewards Points: 528
Replacing Tub Drain
Hello,
Is there a tool besides pliers that can twist out an old tub drain. Mine is over 50 years old and after following the remove instructions for a new part, the cross piece broke. Now there seems to be no way to get leverage to remove the drain. I am assuming that it twists out but I do not know how these things were installed over 50 years ago.
rjordan392 is offline   Reply With Quote
Old 06-24-2008, 01:20 PM   #2
Rewards Points: 1,062
hmmm.
is there a tool that works like a caliper, i.e. that can be fit and tightened inside an orifice ? if there is, i would use that and forget about the prongs inside. of course, soak the hell out of it with WD40.
Old 06-24-2008, 07:35 PM   #3
Rewards Points: 528
I found two tools for removing tub drains.
Check out www.plumbingsupply.com/toolsdrain.html
The dumbell type wrench will not work for me as the cross bars have already broken, so I chose the type that expands to grip the sides of the drain. I ordered it today. Look under "Tub Drain Removal Tools".
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
