Replacing Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2010, 06:20 PM   #1
Rewards Points: 35
Question
Replacing toilet flange
The flange under my toilet is partially rusted away and I want to replace it. The flange is metal and I have cast iron drain pipes. How is the flange attached to the pipe and how do I change it?
czars is offline   Reply With Quote
Old 11-01-2010, 06:07 AM   #2
The flange is cast iron and fits over the drain pipe. It is the packed with oakum and lead is poured into the joint. To get it off, you need to dig out the lead, or crack the flange fitting(JUST the flange, not the pipe) then pry it off.
Old 11-01-2010, 12:02 PM   #3
Rewards Points: 3,130
If the existing flanges isn't too badly rusted away, you can use a repair flange. Lots less work and money.
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
Labor/material costs for replacing toilet flange SpookyLugBolt Off Topic 0 07-21-2010 09:08 PM
Replacing toilet flange pekesfwf Building & Construction 1 06-12-2010 09:22 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
Replacing a toilet flange jayp Plumbing 5 06-11-2008 09:43 AM
