Replacing Toilet Flange In 1/2 Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2011, 12:37 PM   #31
Mark Potter's Avatar
Rewards Points: 150
Originally Posted by sullijos
The Johnny bolts are the rusted ones. I had to use a hacksaw blade just to get the nut off to remove the toilet. I would like to remove the flange but my big issue is that it won't some off. Are cast iron flanges typically bonded or soldered to the drain pipe if that is also cast iron? I don't want to get too aggressive and end up damaging the drain pipe. Any recommendations?
You can keep the existing flange and do it how Alan said or you can get a metal flange with the higher hight they do make them you can solder together.
Mark Potter is online now   Reply With Quote
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
What to do with toilet flange BOUTYM Plumbing 7 09-21-2011 08:17 PM
replacing toilet flange tomie Plumbing 2 05-28-2010 01:35 PM
Toilet flange arrangement with new floor bvsmitty Plumbing 2 01-16-2009 05:51 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 10:09 PM
