Replacing Toilet Cut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2010, 03:14 PM   #1
replacing toilet cut off valve
i am replacing my toilet cut off valve which seems to screw to the copper pipe but when i unscrew it it just spins. ive tried pulling it off but it wont budge.
timwaggoner is offline   Reply With Quote
Old 03-14-2010, 06:21 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
There are a variety of shut off valves for this application. Post a decent picture and we can instruct you a little easier.
Journeyman Plumber
Old 03-15-2010, 07:07 AM   #3
It sounds like a compression fitting valve. Hold the nut and unscrew the valve. You can't get the nut off without cutting the pipe, but you can probably reuse the nut on a new compression valve.
Old 03-15-2010, 07:57 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
I always do what Just Bill said. Re-use the existing nut and ferrule (brass ring that actually does the sealing) with a new compression fitting valve.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-15-2010, 05:31 PM   #5
might be a "shark-bite" post picture
just a guy is offline   Reply With Quote
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 11:43 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 04:34 PM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 07:52 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
