Replacing Stems In Tub Faucet - Need Some Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2013, 12:16 PM   #1
Replacing stems in tub faucet - need some help
http://www.absolutehair.ca/IMG_0247.JPG
http://www.absolutehair.ca/IMG_0248.JPG
http://www.absolutehair.ca/IMG_0249.JPG
http://www.absolutehair.ca/IMG_0250.JPG
Without risking full demo...I'm not sure how to remove the two sleeves surrounding the stem. Are they normally threaded? Is maybe the tile/grout preventing it from turning? I can't even get to the inner one without getting the outer one off first.
This is a rental property I own...and there is no direct shut-off for the tub...so I need to finish what I start in a short period of time...or the tenants will be waterless!!!
I need to remove the two sleeves - remove the stem (which has an extension) - take 'er to the depot for a replacement - come back and install.
Any advice would be appreciated.
Jason
jjklug is offline   Reply With Quote
Old 02-12-2013, 02:01 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
I'm not sure what kind this is but the ones I've seen have a retainer clip that you squeeze and pull off then you can put the control knob back on, thread your screw back in and pull out.
brockmiera is offline   Reply With Quote
Old 02-12-2013, 02:51 PM   #3
There is no retaining ring that I can see. Any other ideas...
Old 02-12-2013, 04:09 PM   #4
Rewards Points: 13,712
Wrap a piece of sand paper around the chrome tube and use a pair of channel locks or a pipe wrench.
Old 02-12-2013, 10:32 PM   #5
looks like the stem has leaked from the crud inside the tube. try squirting some pb blaster or wd 40 inside the tube towards the back where the threads are and pick up a strap wrench. is there an access panel behind the valve?
Old 02-12-2013, 10:40 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Wrap a rag around the trim piece and turn it out with channel locks,then use stem socket to remove the stem
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-13-2013, 09:04 AM   #7
No access panel behind or below..
Old 02-13-2013, 09:14 AM   #8
I think my first step might be to put in a couple of shut offs to the tub way down in the basement where I can see the lines...just so when I start this project...the tenants will have water in the rest of the house...
Old 02-13-2013, 07:55 PM   #9
plummen's Avatar
Its easie/fasterr to replace the stems the stems then cut 2 valves in
Replacing shower faucet Sketch Kitchen & Bath Remodeling 5 08-12-2012 12:53 PM
Garden Hose faucet leaking (replacing) greentrees Landscaping & Lawn Care 9 05-13-2012 03:06 AM
Trying to remove faucet covers access stems tanq50 Plumbing 12 11-03-2011 07:20 AM
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 02:57 PM
Replacing bath tub faucet handles dave6k Plumbing 4 02-03-2010 07:55 PM
