Replacing Shut Off Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2011, 05:17 PM   #1
Replacing shut off valves
I need to install a new bathroom vanity and sink. The old sink will come out completely, but the shut off valves are rusted badly. The Valve is attached to a 1/2 galvanized pipe. Is there something I can soak the valve and connection with to assist with removal. My fear is that the galvanized pipe will break when I attempt to remove the valve. Any suggestions?
RonT is offline   Reply With Quote
Old 02-18-2011, 05:27 PM   #2
Rewards Points: 1,216
Cut it all out get rid of the galvanized along with the valves install PVC or copper whatever.
COLDIRON is offline   Reply With Quote
Old 02-18-2011, 05:32 PM   #3
Lightfoot's Avatar
Rewards Points: 272
you might try soaking them really good with a penetrating oil. I use Knockr'loose or Ballistol, or even wd-40. I'd soak "em and let them sit overnight.
Lightfoot is offline   Reply With Quote
Old 02-18-2011, 07:17 PM   #4
DIY staff
Rewards Points: 7,174
Mighty good chance the pipe will break off---be prepared to open the wall and upgrade the iron to copper.
There is a dandy 3/4 inch steel or brass compression coupling that allows you to saw off a 1/2" galvanized pipe --add the compression coupling on the cut pipe--then add 3/4 inch copper to the other end of the compression fitting and bush down to 1/2" copper.
Google Image Result for http://ecx.images-amazon.com/images/I/21zVpLsad0L._SL500_AA300_.jpg
Good to know if the pipes won't unscrew.--Mike--
Old 02-18-2011, 09:12 PM   #5
use a torch and heat up that valve until its almost glowing. then use 2 pipe wrenches, it'll come out pretty easily
the_man is offline   Reply With Quote
Replacing shut off valves with broken off handles pcampbell Plumbing 14 08-18-2014 06:10 AM
Replacing shut off valves in bathroom Haugenbp Plumbing 11 05-30-2011 09:12 AM
Water hammer after replacing shut-off valves? gspck Plumbing 8 11-24-2010 09:55 PM
Help? Replacing water shut off valves frozenmama Plumbing 4 09-28-2010 07:17 PM
replacing shut off valves glassman Plumbing 1 03-28-2007 11:26 PM
