-   -   Replacing shut off valves (http://www.diychatroom.com/f7/replacing-shut-off-valves-95830/)
RonT 02-18-2011 04:17 PM
I need to install a new bathroom vanity and sink. The old sink will come out completely, but the shut off valves are rusted badly. The Valve is attached to a 1/2 galvanized pipe. Is there something I can soak the valve and connection with to assist with removal. My fear is that the galvanized pipe will break when I attempt to remove the valve. Any suggestions?
COLDIRON 02-18-2011 04:27 PM
Cut it all out get rid of the galvanized along with the valves install PVC or copper whatever.
Lightfoot 02-18-2011 04:32 PM
you might try soaking them really good with a penetrating oil. I use Knockr'loose or Ballistol, or even wd-40. I'd soak "em and let them sit overnight.
oh'mike 02-18-2011 06:17 PM
Mighty good chance the pipe will break off---be prepared to open the wall and upgrade the iron to copper.
There is a dandy 3/4 inch steel or brass compression coupling that allows you to saw off a 1/2" galvanized pipe --add the compression coupling on the cut pipe--then add 3/4 inch copper to the other end of the compression fitting and bush down to 1/2" copper.
Google Image Result for http://ecx.images-amazon.com/images/I/21zVpLsad0L._SL500_AA300_.jpg
Good to know if the pipes won't unscrew.--Mike--
the_man 02-18-2011 08:12 PM
use a torch and heat up that valve until its almost glowing. then use 2 pipe wrenches, it'll come out pretty easily
