Old 03-28-2007, 10:16 PM   #1
replacing shut off valves
i have a couple shut off valves that are so corroded theyeither wont turn or hardly turn would it be ok just to replace the on and off section and leave the old ring and nut.i have half inch copper pipeing.what are the risked of breaking something and making it worse and is there some kind of goop that i can put on the threads in case washer is a little worn.im selling house and have already remodeled one bathroom but have inspecter coming over in a few days and just want to make sure things are ok.
glassman is offline   Reply With Quote
Old 03-28-2007, 11:26 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
If there the same sure you can. I've done this before, never gad a problem doing it this way.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 07:31 AM
I cannot shut water off. Floorwizard Plumbing 12 06-08-2007 05:05 PM
Shut Off Valves Coach Gordon Plumbing 2 04-24-2006 04:13 PM
Pressure Compensating Shower Valves MikeinBurien Plumbing 4 12-21-2005 11:13 PM
