Replacing Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2009, 01:50 PM   #1
Rewards Points: 270
replacing shut off valve
I am ready to replace the kitchen faucet shut off valves. 1/2" copper and replacing compression with compression.
I have bought the ferrite / compression sleeve puller.
I just want to know do I have to shut the valve at the water heater so the hot water would stop dribbling?
And should I use sand paper or something to clean the pipe, remove oxidation and nicks and scratches, before new compression nut goes on? What grit of sand paper would you recommend?
DIYGST is offline   Reply With Quote
Old 01-08-2009, 02:06 PM   #2
Shut it off there and turn on taps below your work area to drain residual water from above. Fine sand paper, wed dry holds up or emery cloth with a gentle touch.
Chemist1961 is offline   Reply With Quote
shut off valve under sink mathmama Plumbing 7 05-16-2010 06:27 PM
Toiler Shut Off Valve DChomie Plumbing 4 09-28-2008 11:13 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 01:44 PM
Water Valve won't shut off armywife Plumbing 1 12-17-2007 06:16 AM
