Replacing Showerhead Gooseneck - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2008, 06:04 PM   #1
Replacing showerhead gooseneck
I am remodelling the bathroom and have retiled the shower. I stubbed off the showerhead gooseneck during the tiling. Now I have to insert a new goosenck into the brass fitting inside the wall. When I screw it in tightly, the bend in the gosse neck points up (the wrong way). I am worried that if I leave it half a revolution looser it will leak inside the wall, even if I use plumbers putty or teflon tape. Is there a tried and true method to replace these gooseneck shower head pipes without leaks? I appreciate any help or advice.
Dave Barclay
dkbarclay is offline   Reply With Quote
Old 03-30-2008, 06:20 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Use a thicker teflon tape and pipe dope on top of the teflon tape.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-30-2008, 10:25 PM   #3
Custom Cabinet Maker
Yeah Pink Tape!!!!!!! Lol Lol
skymaster is offline   Reply With Quote
Old 03-30-2008, 10:32 PM   #4
That pink teflon tape is pretty good stuff.
plumber Jim is offline   Reply With Quote
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
replacing brass shower fixtures; how hard? tarheelblue Plumbing 6 01-26-2008 09:18 PM
Replacing HVAC Thermostats handy man88 Electrical 4 11-19-2007 02:43 PM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 07:31 AM
Showerhead question Mr. Michael Plumbing 2 02-28-2007 07:35 PM
